Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Like Tree11Likes
Thread: Spiral Milling along with a bit of turning (large, lots of photos)
  1. #21
    AlfaGTA is offline Diamond
    Dec 2002
    Benicia California USA
    5,223
    Quote Originally Posted by JHOLLAND1 View Post
    thanks for pics and hx Ross
    are the pistons and conn rods original?
    is the drilled flywheel original?
    j
    J:
    The pistons are new for our current rebuild. Block bored and honed new pistons purchased from JE in LA. Pistons are forged blanks but fully machined inside and out....
    We used to be limited to the available forging blanks when making new pistons for a job. The aspect ratio of old pistons is quite high being pretty tall from pin to crown. A problem for custom
    piston makers in years past. With advances in cutting tools and machinery some makers now offer pistons fully machined from (shudder) billet.....This is not marketing buzz in our case as it
    allows designing a piston of modern material and modern profile on the skirt to classic proportions.....
    This engine had been "hot rodded" by the previous owner. They had modern rods made and drilled the flywheel. This was a classic example of what can happen when modern (relative term here) car
    guys get working on old cars. You have to stay true to the era IMO....you can't make a space ship out of a Piper Cub, but there are guys that will try. Lots of re-work needed here to get a sound foundation
    to build a proper period engine.
    Rods changed to have Babbitt poured directly in the big ends...on old not surface treated cranks i favor Babbitt to thin wall inserts..softer and you don't need to grind to any standard size on the journal (remove less from the original part)
    Main bearings re-done completely...Originals were allowed to run without proper "crush" between the case and the shells causing fretting on both bearing shells and housings. Case with block fitted was line bored
    to give good housing bores. Then new bronze shells were made using the process as described above. Shells Babbited fit to the case and line bored to give the proper crank /bearing clearance....
    The cam was likewise in need of rework...bearings, gear, profile....
    And for those wondering...most if not all the work i do is time and materials....almost impossible to estimate this sort of repair with any accuracy, you never know what you are going to find inside.
    Cheers Ross
  2. #22
    kustomizingkid is offline Hot Rolled
    Aug 2010
    Minnesota
    588
    Ross you have the coolest job. Getting to work on such rare cars with such fine tools, I can only imagine.
  3. #23
    JHOLLAND1's Avatar
    JHOLLAND1 is online now Stainless
    Oct 2005
    western washington state
    1,788
    thank you Ross for tech details.
    JE Pistons operation is most impressive
    j
  4. #24
    Dec 2002
    5,223
    j
    Yes...around here be it a DFV or a 1913 Peugeot, JE is the first choice....Great quality, and good support.
    Cheers Ross
  5. #25
    CBlair is offline Diamond
    Sep 2002
    Lawrenceville GA USA
    4,003
    Will you try to repair the lightened flywheel or make a new one? Hard to believe someone would do that to something that is so rare...I am not any purest but you do have to be realistic. Hot rodding a 32 ford is quite a bit different from something there is only one or two of. It just doesnt seem quite right to my sensibilities.
    Glad at least to see someone with the resources to have things done right.
    Charles
  6. #26
    Mud's Avatar
    Mud
    Mud is offline Diamond
    May 2002
    South Central PA
    9,635
    Inspiring photos of beautiful work, as always Ross. Thanks for posting!
    Again I find myself wondering what machines the original parts were made on and how it was done. I once restored and used a 1908 Lodge and Shipley lathe. If it was representative of the machines of that era, with dials of about 1.25" dia and graduated in .005 increments, I wonder how machines like this ever got built. There sure weren't any machines like your Deckels then, but the cars sure were complicated.
  7. #27
    Aug 2010
    Minnesota
    588
    I don't see the point of Hot Rodding a car like that, and I am a Hot Rod junky. Seems like the first place to start with hopping up a car like that would be to take out the original engine and start with something better in the first place. Then ditch the original everything in favor of better stuff... some people just make odd decisions.
  8. #28
    Martin P's Avatar
    Martin P is offline Stainless
    Aug 2004
    currently Belgium
    1,436
    Great pictures as usual, thanks for sharing.
    As with previous pictures from you I always have to recalibrate my expectations of what stuff that old should look like. Its always better then I would imagine. Tool making machinery from that time seems so obsolete one is tempted to disregard it as junk, but obviously not so. What did they machine that engineblock with for example. A huge horizontal doing 200 rpm with a not-even-HSS cutter? What would that mills tooling set look like? I can not imagine and feel totally disconnected from that aera.
    So much more cool to see it.
    BTW Ross, I picked up the boxes recently and almost broke my back. PM coming.
    Martin
  9. #29
    Dec 2002
    5,223
    Quote Originally Posted by Martin P View Post
    Martin
    Pretty sure i warned you....
    Cheers Ross
  10. #30
    Charles P is offline Aluminum
    Jul 2009
    UK
    51
    I like the nonchalant display of GP Bugatti wheel in the background.....
    Charles
  11. #31
    archimedes is offline Aluminum
    Apr 2005
    harrisonville, mo
    75
    Ross,
    i see what appears to be the hand drawn 2d print
    of the slinger as a background when showing the details
    of the new slinger . . . . its never been asked & i hope
    i am not intruding, but is this a typical approach for
    a project such as this new part? how do you guys
    create your 2d plans & are they turned over to the
    benefactor when the project is completed?
    i really like your creative or maybe coincidental partnership
    of the hand drawn print with the slinger. IMO it makes
    for a great story . . .
    always like it when you get this type of masterful effort out to us
    normal shop rats. living here in missery -- small town to boot;
    i feel lucky you can be in a position to make a choice to do this for us.
    thanks
  12. #32
    Sep 2002
    4,003
    Quote Originally Posted by Charles P View Post
    Charles
    Charles I wouldnt be too surprised if you looked around you would find the rest of the car there too.
    Charles.
  13. #33
    Dec 2002
    5,223
    archimedes:
    The hand drawn sketch for me is pretty common.
    The paper tablet makes a better background for photos than the worn and dark wooden bench top.
    Plus i sort of like the look.........
    I use several methods to solve for the parts i need to make. Often there is a worn or broken example that gives clues to the
    needed dimensions. I will usually sketch the relevant features and their sizes on paper.
    I don't have a CMM so if layout is critical i will use the machine to measure the part and location of features.
    I keep personal note books of the sketches with notes on disassembly and construction details. Some guys go the digital camera route. I do that some, but notes are just better.
    Important finished sketch work is included in the customers files......
    Sketches are also used to enter information into my CAM/ Cad programs I am lucky enough to have a full, up to date 3D plus version
    of SurfCam and further i have full DNC software/Hardware for the FP4NC i use daily.....
    In addition i also have a current version of SolidWorks....
    Often i get work where the original component has been modified or replaced. Old photos and other similar cars coupled with a bit of logic can often solve the mystery.
    Biggest current problem i face is what to do about a replacement....Sold my interest in the business this year, but i will remain for an additional 4 years. New owner wants everything to continue,
    so someone has to be brought up to fill my role here.....
    Cheers Ross
  14. #34
    Dec 2002
    5,223
    Quote Originally Posted by CBlair View Post
    Charles.
    Actually there are two GP Bugs in at the moment along with an Alfa 8-C 2300, a 6-C 1750 ,a Maserati 8CTF a Ferrari LM, a Miller rear drive 122, a Parnelli F1 car(VPJ4) and a Williams FX3/1 .....in addition to the TurCat of course....
    Cheers Ross
