rklopp
- Feb 27, 2001
- Redwood City, CA USA
Does anyone know whether a late model Aciera F5 slotting head will fit an early-model F5 mill? The last-generation F5 design included an alignment pin and slot in the lower right corner of the ram face. The earlier generations used a tapered dowel in the lower left corner of the ram face. I am wondering whether the bolt hole spacing is the same, and the dog clutch dimensions are the same. The Aciera design relies on a retractable pilot bushing around the dog clutch to center the accessory heads on the face of the ram. The alignment dowel and pin and slot are not necessary, as the heads can be trammed manually. Unlike in the photo, the overarm is retracted fully out of the way when mounting accessory heads.
