blkaplan
Cast Iron
- Nov 23, 2011
- Maryland, USA
I am trying to perform a tool change by running T3; M6; and I get a PMC error 104 that the Y & Z are not at the zero positions. Both Y and Z have been Zero'd and the LEDs on the controller indicate they are at Zero. The ATC also indicates its at the home position.
If i go into ATC manual mode, I can get the pot to go up and down but it will not move the arm, the arm forward position led is already illuminated. If I manually move the ATC out of position, the ATC manual mode forward and reverse buttons will work until the machine returns home and they stop working.
Any clues?
Any clues?
