Maho MH 600 E2 spindle problem
Ziculi
Sep 21, 2017
I have a problem with the INDRAMAT KDA spindle drive.There are two errors on the display showing up: "BS" and "S-CIRCUIT"(more often second). I'm interested in what could be a problem, as it happens that everything works normally for 2-3 days and then does not work for 7 days. Is it possible that the problem is a cable from the spindle motor?
Not sure what that alarm is but you could meg test the motor coils w/wires, also might be a spindle encoder alarm for the speed sensing channel. Just be careful with those indramat drives, I'm pretty sure they pack a decent punch for quite some time after you turn the machine off. Judging by the intermittence of the problem it would be more akin to a contamination, cabinet heat, or the less likely scenario of building power issues.
