You really need one of these to be absolutely sure you have the connections correct
Second, From recollection, You send the program to the board First(Mine had an on board buffer)
Im looking at the manual, You need to set parameter 82 to "1"
OR it says Par 80, "1" the control will detect either EIA or ISO, I would just set 82 to 1
First send prog to BTR board, before hitting tape in
Then hit Tape in, and the program transfers from BTR to machine. I say I have to recall
because I sold the last Mori yaers ago with that type of control
Now this is where things get tricky, And I am going from distant memory
I think I see 3 LED lamps in a row there on that board, First, Send your Program
to the board, and one should light, Eiher error, Or Buf/Buffer
If the buffer lamp on the board is lit, THEN go around to the control pendant
and in edit mode, hit the Tape read/punch button. It may take some fiddling
But im pretty sure that is the procedure to get program from computer to machine
This board you have pictured, It does not seem like the exact one I had in the past
it may be just an earlier version.
So, first try the RS 232 tester, They are like 10 bucks at Radio Shack or they are everywhere
on the internet cheap
Then try the procedure I just described, You may just be hitting the tape in too soon.
And the program then resides in the COM board waiting for you to hit tape in again
For punch, I seem to recall just setting the parameter to 80 or 82 on the display, and the program
should run out back when you hit tape in/out
Wayne
