isaac338
Cast Iron
- Sep 25, 2008
- Halifax, Canada
Hey all,
We just got a Mori SL25B at work with a Fanuc 10T control. Got it placed and wired in and the control won't turn on - when you press the power on button, it closes the main contactor for a second, and then opens it again. Nothing is displayed on the screen (it's got an LCD retrofit).
There's hydraulic pressure so I'm assuming it's phased right. I've checked every fuse and breaker that I can see, and they're all good.
I've read the 10 Maintenance Manual but none of the cabinet layouts seem to match what we have, so I don't know where to start troubleshooting. I can't see an input unit anywhere, and there's only one velocity unit. I have 100V and 24V at the transformer secondaries, and I can't find any other transformers.
If I press in the MCC and hold it, the master board shows an alarm of "d" which as far as I can tell says the power unit isn't ready, but I can't find our power unit in the Maintenance Manual. Most of the troubleshooting info I can find talks about how the input unit controls the power unit, but we don't have an input unit that I can see.
Anyone have any thoughts?
