NEED HELP maho mh 600e
Selven1
Aug 11, 2016
Hi
I'm missing parameters for a maho mh 600e with Philips 432 controller. The software nr. is 6702.703/01
Can anyone help me?
For what it's worth------
MAHO parameters are directly related to each machine's serial number. This is due to various options added at or during machines construction. Not sure how close a similar year and size 432 machine parameters would work.
Do you have the manuals? If you load the parameters manually then you have to do it in a progressive sequence. ie. load the first part then restart before loading more and restarting and finally checking that all have been entered and they are correct .If you don't find any from here you might try the .de web site.
Wish I had more to offer.
Might be worthwhile to keep us advised of how you are doing
Post some machine photos if you can---
A very BIG THANK You to Antonmies !
Wonder if any other's could post their constants. Might be interesting to see as a contrast / compare type of thing.
