Results 1 to 4 of 4
    opua is offline Plastic
    Jan 2003
    Port Townsend, WA , USA
    5
    Default DMG 310X M code question
    I'm attempting to develop a sub routine for a bar puller.
    The DMG 310X manuals do not, at least as far as I can see, list the M code to open/close the chuck or collet.
    The common M10/M11 codes inserted on a line by themselves are rejected by the 810D control as being invalid.
    Anyone have any experience with this type of application and the M code required?
    Paul
    mbpp is offline Aluminum
    Feb 2008
    Ireland
    187
    Don't know your machine but I'd try M06 / M07
    Unless you know they're for something else.
    bryan_machine is offline Titanium
    Jun 2006
    Near Seattle
    2,447
    The manual for my CTX 310ECO (ECO not a high line DMG) with a siemens says:
    M437 closing chuck/collet
    M436 open chuck/collet
    M433 open chuck/collet with spindle in rotation // I'm not sure what that is for?
    It also says:
    M484 - internal piece clamping (flanges) main spindle
    M485 - external piece clamping (shafts) main spindle
    Part catcher
    M681 - Part catcher of unloading pieces in position of job (high)
    M680 - part catcher unloaded pieces in position of rest (low)
    I don't have the code right here, but I have a routine on the machine and if memory servers it is:
    spindle stop
    grab part with bar tool using normal moves
    M436
    move with normal moves
    M437
    withdraw bar tool
    Jan 2003
    5
    Thanks for the M codes, correct and confirmed in MDI mode and in the sub program itself
    Good to go
    Appreciate the help greatly
    Regards,
    Paul Z
