VictorStefan
- Oct 18, 2017
Hello all,
Is there any daily user of Aggie Charmille Cut20P erosion machine?
I have problems when i start a cut...
For example, i have to cut a piece who was 80mm thickness. I generate the tec. file, and fill with the corect infos (piece height, wire diam., etc)
When i start erosion, afeter 5-10 seconds, the wire breaks. Then i start to modify my tec. file(in the optimization tab), increasing and decreasing some parameters, but at some points still get that wire breaks and i cant go forward.
My material is steel with 55-58 HRC (dont know exactly), but it shouldnt be a problem.
Its wird because i managed to cut, aprox. 10mm, then get wire breaks...
I chnaged the resin, the wire guides, puted a new wire rol
This problem occur not only on that piece, happen on different thickness. Yesterdat i managed to cut a piece with 20 thickness, but also i had to change a lot of parameters in my tec. file
