sputnikprecision
- Mar 21, 2007
- Malta- Europe
I have an HSS250 machine which gave me all sorts of problems but on the whole I have sorted the machine to give me an appreciatable return in terms of work done with it, however I still have some baffling issues which maybe some of your forum users may enlighten me to them.
I have noticed that sometimes the flushing is non existent. The worktank would look like a stagnant pool of water! On other occasions, it looks like a boiling pot with water sometimes shooting out of the tank and as most of you would deduct, improper flushing leads to compulsive wire breaks and very slow cutting due to the P value reduced down sustantially.
Does anybody know how the flushing pressure on this machine is achieved? The flushing pump is a submersible pump which delivers water into a manifold which has various valves outputing the water. I suspect some valve is not functioning or function erratically. anybody can help in this.
Next I ask something about earthing. The Head delivers various connecting straps bolted to the table. The workpiece would be mounted directly on the table, however I have noticed that if I bridge the workpiece with a crocodile clip and cable to one of these straps, there is a considerable spark and this tells me that for some reason the contact of the straps is not reaching the workpiece 100%. any idea about what may be going on?
