glbreil
Cast Iron
- Feb 10, 2008
- McLeansboro, IL
When cutting tall parts I have a small issue that happens occasionally and I am wondering if there might be a simple programming\tech change that might solve it.
I have attached the roughing program that I often use so you can get the idea of what I am talking about.
The issue - everything is perfect cutting around to the stop where I then shim up the slug and cut off the tab. However when breaking through the tab at the very last few thousandths the machine will usually stop and back up a few times trying to get through without shorting the wire.
On occasion it will back up pretty far and almost get a run at it and when that happens it will jump over the ridge left at the end instead of cutting it off smoothly. When it happens it is to much for the skims to clean up and I wind up with a ridge.
My question is can I jump in just before it breaks through the tab and change the tech to something that would cause it to slow down and burn through without stopping or backing up and if so what would that look like in my program below.
Also what would I change on my tech to cause that to happen?
Sample program;
N004D01P01T01S01G43
N002G03X+006443Y-002868I+006443J+005804G44
N003G01X-006443Y-005804G40
N004G03X+006443Y+002868I+000000J+008672G44
N005G02X+000747Y+000333I+000747J-000673
N006G01X+004000Y-000000
N007G03X+001266Y+005471I-011190J+005471
N008G03X-001266Y+005471I-012456J-000000
N009G01X-004000Y+000000
N010G02X-000747Y+000333I+000000J+001006
N011G03X-006443Y+002867I-006443J-005804
N012G03X-006443Y-002867I+000000J-008671
N013G02X-000747Y-000333I-000747J+000673
N014G01X-004000Y+000000
N015G03X-001266Y-005471I+011190J-005471
N016G03X+001266Y-005471I+012456J-000000
N017G01X+003900Y-000000
N001M00
N002G01X-000100Y+000000
N018G02X+000747Y-000333I-000000J-001006G44
N019G01X+000669Y-000743
N020G01X+006443Y+005804G40M21
N021G45M21
Skim 1 begins here.
These are the tech numbers that I am using. M=5 T=12 I=10 PR=30 P=5 Td=27.5 Hc=11
Thanks Gary
Sample program;
N004D01P01T01S01G43
N001M00
N021G45M21
Skim 1 begins here.
Thanks Gary
