glbreil
Cast Iron
- Feb 10, 2008
- McLeansboro, IL
I few a few technical questions about my old machine. I don't think the wire tension is what it should be and I think checking it should be a pretty straightforward voltage check but I have no idea what voltage I should see at the brake.
So question 1; what voltage should be across the brake wires at the given HC settings? HC1= ? Volts, HC11= ? Volts, etc.
2; does that voltage come directly from the DWC-01 board or from some place else?
I have a number of manuals including most of the wiring diagrams for what they are worth but is there such a thing as a service manual that would have this kind of information?
And if so, does any one know how to get one?
As always, I appreciate your help!
Gary
Gary
