Alarm Problems with Mitsubishi Wire EDM
Results 1 to 12 of 12
    May 2014
    San Dimas, California
    19
    Default Alarm Problems with Mitsubishi Wire EDM
    Hey guys,
    I'm having some problems with my Mitsubishi wire EDM machine, the power went out and when I re-booted the machine a few alarms came up after the OS finished starting up.
    Here are the problems:
    1. S01 Servo Alarm
    2. PR 0025 X Please Ref. Return XY
    I know that doing an origin return would clear problem #2, unfortunately the machine cannot be put into "ready" mode in order to perform the origin return. As for the servo alarm, I am clueless on how to fix it. Any help would be greatly appreciated.
    Some side Notes:
    - I already tried shutting the machine down and restarting it (silly I know but sometimes it works) with no luck, and I have navigated through the menus with no luck.
    - The machine is around 8-10 years old
    Feb 2010
    Emmett Michigan U.S.A.
    66
    35
    35
    I had a servo alarm after a thundstorm, and had to reload the software, thats on an fx-10 also your battery might be dead.
    Bruce
    May 2014
    19
    Quote Originally Posted by bruce h View Post
    Bruce
    Is there a specific way I can check the battery to see if it is shot (sorry I'm relatively new and don't know much). I can try reloading the software, any idea on how long that took?
    Jan 2011
    Indiana USA
    107
    41
    Check the lights on the actual servo drives. I am not familiar with Mits EDM stuff but you may have blown one with the sudden power loss which may very well not have been just a loss of power but also a surge.
    Nov 2011
    CANADA
    466
    40
    150
    I have had both batteries go bad (Large one on control floor and the NiCad on the board) Neither caused a servo alarm.
    I would direct your attention to the servo boards as ConstantWave said. I would try unhooking the wire harness from each one before power-up. Try any trouble-shoot which one is the problem. I do not have an FX wire, but an EX sinker of the same era.
    May 2014
    19
    Quote Originally Posted by ConstantWave View Post
    I shut the whole machine down, powered it all down to check those lights, nothing was on/out of the norm. When I turned it back on the servo alarm went away. Thanks for the helpful advice guys, its very much appreciated.
    Feb 2006
    New Jersey
    1,421
    7
    44
    What model machine, and what is the exact alarm? There should be numbers after the "S01" along with an axis designation, like "S01 Servo Alarm 0056 X" or such.
    You need to turn the breaker off for about 10 seconds then back on to clear an S01/S03 servo alarm. That alarm is generated by the servo amp and only removing power to the amp (breaker off) clears it.
  8. Likes Space Wolf, tvalen1432, roysol liked this post
  9. #8
    Feb 2010
    66
    35
    35
    Thanks MitsTech thats good to know
    Bruce
  10. #9
    Oct 2017
    Michigan
    Same issue on a fa10, was this ever fixed?
  11. #10
    Oct 2017
    Michigan
    Quote Originally Posted by jm0502 View Post
    Battery in the xy board was bad.
  12. #11
    Nov 2014
    13
    42
    Mits Tech: Could you check out my thread if you have time? I have a Mits FX10 and there is a few issues going on but I am thinking they are due to either the resin pump going out or the circulation pump(?) going out. It keeps giving me either dirty side low or clean side low and neither are low at the time of alarm. I could really use the guidance.
    Thank You,
    Tvalen1432
    (sorry if that was rude to ask)
  13. #12
    May 2005
    296
    241
    8
    "I shut the whole machine down, powered it all down to check those lights, nothing was on/out of the norm. When I turned it back on the servo alarm went away. Thanks for the helpful advice guys, its very much appreciated."
    You need to turn the breaker off for about 10 seconds then back on to clear an S01/S03 servo alarm. That alarm is generated by the servo amp and only removing power to the amp (breaker off) clears it."
