Charmilles Robofil 200 Problems
Ed Rodrigues
Mar 6, 2017
I've got a 1988 Robofil 200 wire edm.
It stopped right in the middle of a cut and I could not get it to move.
The screen went blank except for a message at the bottom. (PO5?)
I had to shut down machine and restart with initiation button pressed.
Nothing came up, no lights or screen.
It does beep two times, I usually hear three.
I'm pretty sure the screen works as it blinks when I shut it off again.
Tried to reinstall software but it won't read a disk.
Something won't let it do a complete restart.
Charmilles no longer supports this machine and having problems finding
anyone in California to take a look at it.
Any ideas?
Any ideas?
Give Milan a call. He may be able to help. 562-569-8428
Any ideas?
A little more info since the above message.
The battery card has lights on it, 6 green and 2 red.
If all green are lit up, and the red are not lit, your good.
Mine has two green lights out. (marked DALC and 5DD)
And two red lights that are lit. (marked RES DXT and NMI)
hi Ed Rodrigues
I have the same machine. Its in working condition as of now. If it is possible check all the voltages on the power supply with a voltmeter. And if you get a solution to the problem put it out here
