Got a charmilles cut 400, have a problem with the threading jet instead of a straight jet it just sprays water meaning that the wire doesnt thread from any height's above 2" is there a way to adjust the jet?
Adding a nice filter to all the small fine water circuits (threading,wetting,and aspiration)Sounds like you have some trash stuck in your threading nozzle.
That or you've broken it, which is easy if it's one of the all ceramic type instead of the ones with the ceramic insert.
Remove the upper nozzle, then the upper nut.
Be careful not to drop the guide, extension pipe, and nozzle out when you do.
Turn the threading jet on/off a couple times to blow any trash out.
Now remove the guide, extension pipe, and nozzle from the upper nut and clean the channels in the nozzle.
Check that the ceramic in the nozzle isn't cracked.
If you have a microscope, check your guide too.
Replace them if they are cracked or broken.
Reassemble and check the jet.
During reassembly take extra care that the guide remains seated in the nozzle and the extension tube is on straight.
If it's good do a guide adjustment and you are ready to go.
Sorry I thought you said older 400 my badGot a charmilles cut 400, have a problem with the threading jet instead of a straight jet it just sprays water meaning that the wire doesnt thread from any height's above 2" is there a way to adjust the jet?
But still the filter is not a bad option it can't hurt any thing
ALWAYS have a new thread jet on hand.
Make sure you get the right size hole according to the taper angles your cutting
Big taper big hole
If when you put it togather and it don't hit the guide with perfect cone spray at UV 0,0 it's fucked
Don't attempt to comp it
Here's a easy solution from novotec we can get you 10% off if you order with us
Sent from my SM-G975U using Tapatalk
Dude your not contributing in any wayI didn't know east Lansing was a place in the aaland islands...hmm
Notice
