CUT20 P problem
Results 1 to 6 of 6
Thread: CUT20 P problem
    Oct 2017
    ROMANIA
    12
    Default CUT20 P problem
    Hello everyone,
    I have a problem with my machine, Aggie Charmille Cut 20P
    I have a error "[E20106]:clean reservoir water level is low". I searched in the manual, but it only say to check the water level (wich is ok) and the water circuit system-> here i have a problem, i dont know what and how to check.
    Also, i saw that i have no circulation on the resin reservor (there are 2 hose there)
    Aug 2010
    New England
    226
    27
    there is a float switch in the clean tank that is failing or a hose or flow is hitting float triggering alarm. That or wiring is bad. Find float switch it is in a grey block with conductivity probe.
    Oct 2017
    ROMANIA
    12
    Aug 2010
    New England
    226
    27
    yes sir. if you go int diagnostic you can see if they actuate. or check in the white junction box mounted over the pumps the one with lots of wires sticking out the bottom.
    Oct 2017
    ROMANIA
    12
    Thank you!
    Tthe problem was there, i just had to clean the magnets
  6. Likes roysol liked this post
    Aug 2010
    New England
    226
    27
    My Pleasure!
