Hi ErnieD:
I've cut POCO electrode graphite and it is a royal pain in the ass.
It IS possible, but there are some specific things to pay attention to.
All of what Brian Pfluger has said is the same as my experience has been; here are the details I remember:
First; if your machine doesn't have dedicated graphite settings (and a machine as old as a Japax may not) you need to do the following if you start with settings for steel:
1) Open up the Servo Gap
2) Bump the Off Time way way up
3) Drop the feed rate (if your machine has a setting for that) way way down
Other things to remember:
a) Do not try to cut without almost perfect flushing (so no cutting from the edge on a non-submerged machine)
b) Stick with only the best grades of graphite or copper graphite: POCO 3 or Angstrofine are good. POCO C3 is a good grade for copper graphite.
c) Do not attempt to do milling or any other operations on the electrode that could open up a space between the flushing nozzles and the trode surface before burning it...you MUST have sealed flushing especially on a non-submerged machine.
d) Expect lots and lots and lots of wire breaks
e) Expect it to go SLOWLY...very very slowly, so schedule it in when there's no other pressure on the wire.
f) Charge a lot...it's a pain in the ass and dirty as hell, so you'll have to clean the machine afterward.
g) Talk the sinker EDM operator that's going to use the electrodes into using telco copper or copper tungsten instead of graphite if there's any way you can; both wire beautifully compared to graphite.
h) Dry the electrodes really really well before you put them in the sinker. A lit 100 watt bulb for 24 hours in a box with venting to let the moisture out is a good start.
Good luck with it; let us know how well it worked out.
Cheers
Marcus
Implant Mechanix – Design & Innovation - home
