Hi again KennyBoi:
The most common grade used is Tellurium copper usually abbreviated to "Telco"
This grade is popular because it's very easy to machine so it's nice to make electrodes from.
It is said to be inferior in burning performance to C101 oxygen free copper, but I can't say I've noticed a difference and I've tried both.
There are two things about copper trodes:
1) Machining them leaves them lousy with burrs, so it can be a real nightmare deburring them if they're complex.
2) There is a certain power range in which they're happy...they wear too much with high amperage burns, and they make burn berries on my machine at super low amperage burns, so they're best for trodes you can comfortably hold between two fingers.
Copper trodes do well with some generators and seemingly not so well with others.
Asian machines apparently suit copper very well, and I read somewhere that copper was the GO TO material for Japanese machines in the past, so it kind of makes sense.
On the other hand, I run an All-American (Hansvedt) machine and I have no problems.
One of the toolrooms I worked in back in the day used copper for picking out fine details on a Charmilles and were happy too.
Copper wears more than graphite in general, but it's not as dirty in the cut.
I use copper mostly to avoid the mess of machining graphite, not for any superior performance or anything like that.
For tiny trodes I like to use copper tungsten, but it's EXPENSIVE!!!
I find it to be intermediate in wear performance between copper and graphite but I seem to be able to do better with it than any other trode material on the really tiny stuff.
Going back to Angstrofine graphite...be sitting down when you get prices, and don't plan on making car bumper mold trodes from it.
It's still graphite and still shitty to burn, but I've had better success with it than with other POCO grades because it is so uniform and the particle size is very small so it's mostly graphite and not so much coal tar binder.
Copper is a gazillion times easier to wire cut, and copper tungsten is very close to copper for wire cutting.
So in summary: If I was choosing material that was mostly going to be wire cut or was a simple, open, easy-to-mill shape I'd pick Telco because it's clean to machine and simple to wire.
If it was going to be lots of fussy little milling or grinding I'd choose graphite to avoid the burrs.
If it was going to be a big trode (bigger than a fist) it'd be graphite (copper's HEAVY and many modern servo rams can't handle a lot of weight).
It's also easy to buy in big blocks.
If it was super tiny I'd choose copper tungsten or Angstrofine graphite.
Cheers
Marcus
www.vancouverwireedm.com
