Bradracer18
- Feb 9, 2012
- central, USA
Guys-
We often recut/resharpen knives which vary from 2-4" tall, and from .500-.750 wide. They vary only from different part numbers, meaning when a part number comes in for resharp, they will be all the same size. At times we can cut up to 100-200 of these.
My current method is to hold these parts in a vise on the table, and I cut 1, and reinsert the next and cut again. Works pretty well except I have to be around the machine every 20-30 min (depending on the part) to change the part out. Doesn't make for me being very productive in other areas. Is this how you guys would approach the job?
The thickness or width (section I grab with the vise) is ground....so I had in my head that maybe I could stack these parts say 10 wide and make the machine cut for a half a day or something then come back and knock the slugs off maybe? I haven't done that type of work before but it sure might save time. And another concern is the ground width this time might be .4995 and next time it might be .499, so if you program .499 and they are .4995 by the time you get to the end of the 10th one you would be quite a ways off center. Curious is there is a way to make up for this in the program.
Brad
Brad
