register
Hot Rolled
- Apr 26, 2008
- San Francisco, CA
Novice EDM operator here. I probably have 20 hours on the machine I’m running, an Agie CUT E 350.
Cutting a part in steel this morning that I’ve run before (same program as previously used), I’m getting an error:
“GEN-0686 - The Difference of the voltage read on upper and lower current pick-up is too important [AWR].”
It’s the weekend and this isn’t a super-urgent job, so I don’t want to bother my usual go-to for a question like this. Does this error mean I should rotate my contacts, or is it likelier to be an issue with my setup/program?
Henry
Henry
