EDM Drill time
Results 1 to 11 of 11
Thread: EDM Drill time
    Dec 2014
    Michigan
    21
    Default EDM Drill time
    I've only ever ran one EDM drill ever and I'm curious as to how efficient it is.
    So my question is how long (on average) should this take with the correct settings?
    1.5 mm hole through 2" of hardened 420 SS (50-54 RC)
    Takes me on average about 30 minutes
    Jun 2004
    Idaho
    256
    155
    50
    That seems like that is much to slow. Lots of questions here. What machine and power capability, electrode material, the condition of the machine, condition of the water system, doe's it have good flush pressure, good spindle speed. I do holes like that in around 5 minutes or so.
    Bill
    May 2005
    CA
    919
    161
    Something is wrong. That shouldn't take more than a few minutes.
    What is your flushing pressure? Brass electrode?
    PM
    Aug 2005
    CT
    7,532
    248
    1540
    30 minutes? Wow!!!
    Sure, I have a 75Amp generator, but 2" of steel is sub 5 minutes, Stainless maybe 3 at most.
    Aug 2006
    greensboro,northcarolina
    2,129
    107
    397
    I agree 3 -5 minutes is what it would take us. Brass no core electrode.
    Dec 2014
    Michigan
    21
    Sorry for the delay.
    Charmilles HD-8 25 amp in decent condition with brand new pump
    good flush pressure and spindle rotation speed (I think) not sure if that's adjustable
    With the 1.5mm electrode I use these settings
    On time 60
    Off time 30
    Current 15
    Capacitor 0
    Gap 3
    Speed 1.8
    Pressure 45-50 kg/cm2
    Apr 2008
    Auburn Hills, MI
    225
    25
    45
    Keurb,
    Try one of these settings...the machine I ran had a 60Amp power supply, but hopefully these might be of some use to you.
    Dec 2014
    Michigan
    21
    Ok I will give these settings a shot when I get some time and let you know. Thank you!
    Dec 2014
    Michigan
    21
    Brian Pfluger,
    I tried those settings but it was slower and barely even burning.
    Nov 2015
    45
    6
    7
    Default Parameter change?
    Quote Originally Posted by keurb View Post
    Brian Pfluger,
    Sounds like parmeters are not correct for material and maybe electrode? I ran HD8 drill and it was a very solid little machine.
    Do you have manuals and there should be settings listed for material/ electrode selection. We are using some new oil in our hole popper and it makes crisp clean holes in Carbide and drills much faster . Maybe slightly slower in steel. But better results and seems like less recast also. Which helps with wire breaks on the Edm lead in cuts.
  11. #11
    Dec 2014
    Michigan
    21
    JTB3,
    Yeah the settings that I posted are straight from the manual for brass to steel so I'm not really sure where to go from here.
