dear friends
i have HURCO 900M spark erosion machine
power board failed so i repaired it
this all took above two months and now there is no x y z axis movement!
meanwhile i found out that battery on logic board has failed!
would this be the reason for no xyz movement?
sparking is ok if i check the sparking manually by putting wire between electrode and ground.
how the xyz motors are fed supply and how can i check the normal machine movement without battery?
please help!
sanjay
please help!
sanjay
