float89
- Oct 28, 2015
- Upper Pennisula
Hello everyone! First post for me. I figured I better get on here and start utilizing the vast knowledge PM has to offer.
Ok, so we have a Current EDM CT400 Drill that we use for deep hole drilling of sized holes ranging from .030" to .200" using brass electrodes mainly thru stainless. The electrode guides or bullet guides, as our supplier calls them, are costing us around $150 a piece for a standard guide??? When we purchased the machine a year ago we needed to hit the ground running and bought the sizes we needed but now that some are wearing out I want to start making our own.
1. Are any of you guys making these guides?
2. What material are you using or what should I use? We have some 17-4 or 455 stainless on hand but not sure if I should make them out of some pre-hard and them send them to heat.
3. what kind of fit works best for the electrodes. Some of the guides we have received are over .002 clearance which doesn't really make sense to me. What would be the tightest fit without risking locking it up the guide when running. we have to hold position pretty tight.
4. What about possible coatings? like A TiN or even hard coat chrome.
My plan would be blank out a bunch of these on the swiss and hole pop them with the smallest size we have and then use the wire to bring them to whatever size needed.
Any insight would be Great.
Thanks!
Tom
Thanks!
Tom
