Our machine is only 5-6 years old. It will be cutting fine when suddenly the parts have a .012 inch taper (top to bottom). We realign the machine and everything cuts fine for awhile then, wham! Its cutting a taper again. The pieces being cut are less than an inch in diameter. We have been cutting the same parts (and material) since the machine was brand new. They (the parts) are set up in a multi-piece fixture so, it moves (almost) the entire length of travel. The fixture is not moving / is not the problem. It gets greased regularly and the factory has been no help. Any ideas or help would be greatly appreciated.
Thank You,
Crazy
Thank You,
Crazy
