Hello everyone!
So I run a Mits FA and FA-S at a tool and die shop in Green Bay and recently I've been having problems with the FA dwelling when it reaches the 2nd skim pass. When it reaches the 2nd skim it will start off very slowly and eventually stop and sit in the same spot. When it stops it still leaves the machining, fluid and wirefeed on but it just sits in the same spot usually leaving a line unless I catch it early enough. The only thing that will work is if I turn the PM(power master)on varying or optimum, but I can't finish with the PM on or else it will use a roughing e pack with the finish offsets! I also use esprit to program. I'm sorry if this is worded badly/lack of info but this is as best as I can explain for I'm fairly new to this and don't know all the lingo but if anyone can help it would be greatly appreciated! Thanks for your time!
