conceptdevelopers
Cast Iron
- Jun 16, 2007
- Garland TX
I started having problems last Monday with what I thought was the wire breaking. I went through all the normal maintenance, power feeders,cleaning every thing. Then the wire started "backing up in the upper unit. I was trying to cut Friday and it would run for a few minutes and I'd here a pop coming what it sounded like the back by the chopper. I took the plastic cover of the upper unit to watch what was happening. It would run for a few minutes, I'd hear this odd pop, and the wire would stop feeding and backup, or bunch up in the area of the pipe. Its not breaking the wire. The only thought I have is the bearing in the lower unit in the ceramic wheel or the rubber wheels in the back at the chopper. Those back rubber wheels that grip the wire do have a groove in them use over the years. One more thing. When it backs up in the top I can raise the head, hit the wire collect button, and manual feed and it will pull it through and make that sound that they do after threading is complete to the chopper and try and cut. It just does it again.
Hope this is not to wordy but I didn't want to leave out any information.
Thanx much for your help
Steve
Steve
