dsergison
- Oct 23, 2003
- East Peoria, IL, USA
I just read this from
http://www.edmtodaymagazine.com/AAweb2_2010/TechTips2010/TechTips2008/TechTipsS-0-8.pdf
Add a Safety Screen To Your Resin System
Have you ever thought about the nightmare possibility of all those resin
beads in your resin tank being circulated throughout your dielectric system?
You can be sure that those shops who have had to pay a couple thousand
dollars for a factory service engineer to clean those beads from the
solenoids, lines, valves, flowmeters, pumps, filter housings, jet nozzles,
and numerous other components that make up the dielectric system have.
The center lance of a deionizing bottle contains a filter assembly that
keeps the beads in the tank from escaping. Sometimes rough shipping can
either dislodge the filter from the lance, or cause the lance to separate from
the tank head. If this happens, the machine will rapidly pump out the entire
contents of the resin bottle into your machine when the conductivity system
calls for deionizing.
The solution is an inexpensive secondary filter screen assembly that is
inserted between the outlet side of the resin bottle and the hose leading to
the machine. This secondary filter contains a clear bowl which allows you
to monitor the accumulation of resin beads on the screen. If the resin bottle
fails, the machine will cease deionizing, and you’ll see the screen clogged
with beads through the clear bowl.
The secondary filter screen is a cheap insurance policy that you can’t
afford to pass up.
afford to pass up.
