Mitsubishi FX10 dirty side low + more
Results 1 to 3 of 3
    Nov 2014
    13
    42
    Default Mitsubishi FX10 dirty side low + more
    I have a Mits FX10 and there is a few issues going on but I am thinking they are due to either the resin pump going out or the circulation pump(?) going out. It keeps giving me either dirty side low or clean side low and neither at the time are low. But at times the clean side is not getting enough water and gets low but off and on and erratically. No specific time or situation really except its primarily during roughing. I used to always get a U827 Pump/Chiller alarm also the generic sequence error.
    My question is do the pumps have a water low cut off alarm/switch in them? Say one pump isn't getting enough flow to or from it there for triggering the water low alarm? Or could it be the sensors in the tanks are bad. I cleaned them and they look ok but IDK for sure. My other question is which pump feeds into the chiller? And could there be clogged chiller issues causing the prob? If so how do you clean it out? It's just a radiator type box above the dirty tank with no alarm panel or anything like my fx20 has. I cleaned the fins of a lot of dust n oil but not sure what to do internally if there is anything I can do.
    Any feed back is welcome,
    Tvalen1432
    Jun 2016
    HUNGARY
    17
    30
    I get clean side low messages usually when my edm filters going full. There is a pressure gauge that shows if there is a problem there but mine seems to show false data. It can be something else for sure, but worth a try.
    Gl troubleshooting and have a nice day!
    Mate
    May 2005
    284
    149
    What msrbl said about dirty filters. Even with clean ones, if you don't have your flush nozzles sealed to the workpiece, you can draw more water than the filters can flow. If your volumetric flow meters show more than 4-6 liters per minute, it won't keep up. The float switches do go bad, I've replace several in different areas of the machine. They can get dirty, and not read. They can get dirty and not move at all.They can fail to float any more. They can electrically fail internally.
    On my FX10K the chiller (not heat exchanger), is fed by the filter pump, and the tank circulation needs to be on. The chiller alarm is if it is not on, in an error mode, or the temperature delta T is more than 5 degrees. None of that applies to a heat exchanger. Hope that helps.
