I'm learning to run an Agie Classic S and have a few questions. First, I'm cutting a die detail with land and taper. It started off by cutting the taper followed my skimming the taper cut. I didn't mean to skim the taper but it did and another thing I need to figure out. After this it went on to the next detail which is a dowel hole. I don't see anywhere on the piece details screen where it's going to go back and cut the land. Will it go back and where do I look that shows me this? Secondly, when the machine starts to cut it takes off slow. I'm guessing this is normal as the Charmilles I use to run did the same. However, with the Agie it will get about a 1/4 of the way around a .500 dia. hole before the power kicks up and cuts with balls. Can this distance be changed anywhere so as it kicks in sooner?
Thanks all.
Thanks all.
