float89
- Oct 28, 2015
- Upper Pennisula
New job we just got and normally all of our Wire stuff deals with features on an existing part where milling is a challenge (medical). This particular part I believe is good for stacking. its an elbow shape with one outside wall having strait cut teeth. 6mm thick about 2" x 3". no internal features.
My question would be should I take a skim cut? based on qty. of the order and stock prep I'm thinking a stack of eight. Everything is ±.004" so no worries there but I worry about wire lag on the center pieces in the teeth... The fanuc has corner rounding built into the control and I know its a big sales pitch item but how effective is it? By not using this wire for a lot of thick and complex stuff should I be concerned with just a rough?
I am hesitant on the skim not because of time but rather the parts moving when i get close to the tab and then try and run back for the skim. Materiel is 17-4 SS and even though it is going to be in annealed state we have to mill it down to size from 1/4" so I know there will be at least a little stress built up in the material. Maybe multiple tabs?
Any Advice would be great! Seems like gravy work but I just don't want to run eight pieces and end up throwing them out..
Tom
Tom
