Rapid movements following a G77...
Results 1 to 7 of 7
    Feb 2016
    Indiana
    5
    Question Rapid movements following a G77...
    I suddenly experienced an issue with rapid movements (G00) following a g77 p# line on our Charmilles wire machine. I havent ever experienced this in the past so its confusing that its suddenly happening and why.
    I am burning halfway around a round part after a 3 point center find. Generally I would find the 3 points manually but lately running more than 2 or 3 parts, i've been writing in the the block of code for locating into the beginning of the program so i can hit go and walk away.
    After manually locating the first one and setting Points 1, 2 and 3, I wrote this into the beginning of the program:
    G77 P1
    G70 B0
    G74 P13
    G00 Y1.0
    G77 P2
    G70 B270
    G74 P14
    G00 X1.0
    G77 P3
    G70 B180
    G74 P15
    G79 P10 B0
    M50
    G77 P10
    G92 X0 Y0
    The rapid movements in Bold are having issues. The first one (G00 Y1.0) gets completely ignored (no, its not already at Y1.0) and skips right to the G77 P2 movement. Even when I put it in single block. The second rapid movement (G00 X1.0) is even more odd. Instead of going from X-0.01145 (Point 2's X coordinate) to X1.0, It goes to X1.98855 which is 2 inches incrementally from where it started. So not only is it ignoring the first rapid all together, Its also moving incrementally when the machine is in absolute mode AND adding an inch to that movement. I made sure the main and sub programs do not have a G91 anywhere so i dont know why its moving incrementally. Not to mention the extra inch of movement. And it is actually an extra inch not just a scaling issue. I plugged in G00 X2.00 and it went to X2.98855 which is incrementally 2 inches from where it left (X-0.01145) plus an extra inch. I tried writing a completely new main program and had the same issue. I wrote another new program just for locating in a different directory all together and still had the same issues. I erased all of the G70's and G74's and still the same issue:
    G77 P1
    G00 Y1.0
    G77 P2
    G00 X1.0
    G77 P3
    This still did the exact same thing. Once I erased the G77's the rapid movements did what they were supposed to do. Then I tried this:
    G77 P10
    G00 X-1.0 Y0
    When I ran it, it ended up at X-2.0 Y-1.0.....
    If I type a G77 movement into the MDI line, and then a rapid movement, It works fine. Just not in a program. I added G91 in front of the rapid movements in the location block of code and it ran exactly like it should. This is my current solution. But if I remove the G91's or replace them with G90's it has the original problem. Using incremental movements in the location block of code works fine and is the easy quick solution. I just prefer to always program in absolute mode to avoid confusing myself and make the programs themselves easier for me (and others) to read and figure out what exactly its doing. Plus I want to know what is going on here and why. I would appreciate any input. Thanks.
    Feb 2016
    Indiana
    5
    Forgot to mention that I also plugged in several G00 Y1.0 lines in after the first one in case it was a read ahead issue...Ignored all of them...
    May 2005
    Republic of Arizonia
    1,397
    340
    Iím not familiar with your machine.
    On a makino , Iíll input the hole size that Iím looking for and the degrees per touch off and how many edge find cycles to average.
    If you have the manual with the G codes.
    What does it read for center finding on a circle?
    May 2005
    1,397
    340
    Maybe itís a
    G77 X,Y ,angle , number of tries...
    If X,Y are greater in length then your radius
    Or
    G77 with a length longer then hole size.
    This would be irrelevant to the coordinates.
    May 2005
    1,397
    340
    Maybe what you need is to set 0,0 in the coordinates.
    Example:
    G54G77 etc etc....
    Jan 2013
    Plainfield, Indiana, USA
    1,473
    1095
    751
    Try a 'G90' in front of your G00 . . . makes sure your are back in Absolute coordinates.
    May 2005
    1,397
    340
    Did some reading.
    A makino uses G77 for finding center in a hole, but doesnít change coordinates...
    So you would use G91 when using G77
    A G83 is a hole measurement and coordinates are set to the center of the hole...
    Makino
    Example:
    Start in a work group say G54 Program
    The some where along the line a G55G91G83
    and define the additional information for G83.
    Another line of code after finding center sets coordinates to that center...
    Probably specific to your machine, if it has a G83 available.
