In that case, I would try and gang up a bunch of parts, write and run a program that did all of the taper, then write and run a program for all of the stratified wire/straight stuff.
You sound like a very creative person.
I hope your boss appreciates the extra effort you are willing to put in for cycle time's sake.
I would add on thing while on this subject.
The cost of stratified wire is usually only justified when the machine is at full capacity.
In other words, if stratified cuts twice as fast, the hourly operational cost is twice as much.
Using stratified wire makes sense when you don't have enough hours in the day.
It saves you the cost of buying another machine...
Make sense?
It may be a better plan to continue to use the half hard and focus on setting up/programming in a manner that allows you to run unattended 24/7.
When running 24/7 still doesn't get the work out fast enough....then switch to stratified.
Where are you at in Ohio?
I have a business that does EDM consulting, program and fixture design, ISO certification help, training, and machine repair...
All at a crazy fraction of going to the OEM.
Not sure if you have dealt with Charmilles on machine repair yet...but they are most definitely not cheap...
I am...
Especially given the fact that you are only a car ride away.
Call or email me directly if there is anything I can do to help.
I know Charmilles machines very well and am actually a poster child for Esprit...
Check this out...
ESPRIT Solutions in Industries (I am the bald guy on the second one down)
And here's this...
CAM Shortcuts Simplify Lights-Out Burns : Modern Machine Shop
Jay Crumb
Advanced EDM, LLC
jaycrumb@sbcglobal(dot)net
(440)567-five eight zero eight
