dsergison
- Oct 23, 2003
- East Peoria, IL, USA
trying to determine if my guides need replacing. I'm running .010 brass. I notice a little vertical striping and so I put the guides under a microscope, with a piece of wire in them, and they are 10% or more over the wire diameter. but very round, so I suspect they are for larger wire.
I see .250mm guides say .252 which would seem to say 1% clearance is new. I probaly shouldn't any more than see a sliver of light perhaps between the guide and wire when back lit under a microscope?
I am ordering a new set, I just wonder what is the normal fit is, and what the normal life is with 1/2 hard brass wire (not tapering). Should I keep a spare set on hand or do they last through many many 5kg spools, or how many hours etc...?
'98 robofil 290
Thanks, Dan
'98 robofil 290
Thanks, Dan
