Hi RJT:
OK, since you have a C axis but no rotary table for the sinker, here's how to do it.
Mount your round workpiece to the C axis, clock it in, and reverse the polarity of your burn.
Mount your flat electrode in the worktank aligned with the X axis and the engraved surface in the XZ plane behind the workpiece (in the Y+ position) so you can see easily what you're doing and you can direct your flushing wands more easily.
Write your code as I've described; make a 1 degree index (or whatever you decide is reasonable) with C, then make a corresponding X axis shift to bring the trode and the rotated workpiece into proper alignment, then do a burn in the Y+ direction.(there is no need to have any of these moves occur simultaneously with any other axis; they can happen sequentially)
Back up in Y when that burn is done, index again in C, advance the trode in X, and do another burn in Y+.
Rinse and repeat for one complete rotation of the C axis.
It'll work slicker than snot and won't cost you a dime in new tooling other than what you may have to cobble together to mount your job on the C axis.
With regard to making the trode; here's a neat trick for cutting shapes that are tough to make with rotating cutters:
If you have spindle orient on your VMC you can use it as a big CNC shaper to engrave patterns like knurls and other features that are repeating patterns of a constant cross sectional profile.
Suppose your pattern is a 30 deg diamond knurl.
You make a single point shaper tool with the proper cross section, orient it properly using spindle orient, and then write a simple bit of code to whistle it across your workpiece in your repeating pattern without rotating the spindle.
Then re-orient to the other cutter alignment and whistle across the workpiece in the other direction to get the cross pattern.
A simple subroutine will let you make these trodes pretty easily
I've used this tactic to shape tiny profiles for lighting fixture molds that were impossible to cut any other way, and if you get the top rake right on the tool and lube it; it will cut a beautifully smooth feature, especially if you make copper trodes instead of graphite trodes for this job.
Cheers
Marcus
Implant Mechanix – Design & Innovation - home
