Im somewhat of an EDM novice, 4-5yrs, have alot to learn yet, I dont do alot of wire work normaly at our shop, but at times i get a group of parts that need burned. I have a good newer machine but i never totally convinced the boss to invest in a fixturing system, a $5-$6 thousand system did seem too much for a $140,000 machine, but it is what it is. I normally have flat bar stock that are just clamped flat to the table and no fixture is needed. But the need for a leveling system comes up time and again. Im confident I can make one, in shop, that will serve my purpose. I have an idea for one that i think will work good. I'm going to try to explain my concept as best i can and would like any feedback or opinions anyone may have. Disregarding any specific dimensions or material type this is what Im thinkin. I'll throw out some dims just for perspective. Two plates 5"x7" 3/4" thick, machine a spherical pocket with 1/2" radius approx 3/8" deep into the center/face side of both plates. Now a 1" ball bearing can be sandwiched between plates. The bottom plate would simply clamp/bolt to table. The top plate will have holes for 4 set screws and 4 shoulder bolts. Four thru holes, oversized for clearance around shoulder bolt, one in each corner, tapped hole in base plate cooresponding each bolt. Now I have btm plate with recess facing up and top plate with recess facing down a 1" ball in between as a pivot point. In between plates at each bolt hole is a die spring plus a die spring on top of top plate at same locations. A proper length shoulder bolt goes thru top spring, top plate, bottom spring, and threads in to base. Now top plate is suspended with spring pressure but can rotate/pivot on ball. Top plate will also have 4 tapped hole at the centerlines of X and Y between shoulder bolts. So , say the sh bolts are at (X,Y).. (-3,2)(-3,-2)(3,-2) AND (3,2). Tapped holes would be at (-3,0)(3,0)(0,3)(0,-3). A long set screw will thread into each hole of top plate down to base. Now to adjust top plate for level, turn set screws in/out accordingly applying more or less spring pressure to plate moving it up or down. The spring pressure will have to be balanced so that the ball/pivot is always pinched tight between plates but top can also tilt as needed. I hope most of you followed that, and the big question do you think it will work. Thanks for any comments in advance.
