Hello all
I recently started working on this old Agie DEM 250 doing some simple straight path cuts through carbide. Looking for some advantage, because this machine is eating time and wire.
Right now I'm cutting through these carbide blades which are just an 1/8" thick x 4.5" long x about 1.25 tall piece of carbide with a 25 degree bevel along the length of one side, which makes the cut around .300"
The blades come in all chipped out and so the cut is about .030-.050 deep into the material.
Cutting with .012" hard brass uncoated wire, and it takes 2 hours to make a pass. Babysitting it is fine, but it's eating 20mm/sec of wire.
Is there some way I can juice this up, or is this an acceptable speed for this machine?
While standing around, I hatched a genius plan to submerge the whole working area with a removable plexi enclosure that would drain out into the pan which collects the water right now.
I believe this machine has a submersion tank somewhere but I got a very cross reply when I asked about it. Maybe the old man bumped his elbows on it too many times and never wants to see it again? More likely, he broke it doing something in his constant panic state and doesn't want to think about it.
Either way, I have a great idea and would totally like to build a fish bowl for this EDM machine, if it's going to improve the speed.
Will it?
Will it?
