What's the fastest possible way to sinker EDM a deep D0.04'' hole?
kerk
May 23, 2018
if i absolutely have to use sinker edm to punch a 0.6'' deep hole, what setting would have the fastest results? i am using a mitsubishi if that helps
If you are trying to edm a hole with a 0.040 diameter 0.600 deep in steel, you are limited to very slow removal rates because of the very small electrode area . . . no way to rush that.
Switch to small hole edm, it is very fast.
Regarding to Charmilles sinker if your first priority is time then you should accept some wear on electrode.
You have different choices for material of electrode to over come this wear but if the wear is not an issue here then you can consider to surpass the strategy barrier of generator settings. These parameters usually prohibit the control to sink too quickly. You can increase Servo(S) and decrease Protection(PR)and use Isopulse Mode(M=7)with minimum retraction(R)and maximum utilization(U). The other parameters are case dependent(to avoid arcing and electrode deformation due to heat build up).
A good flushing is a must.
