Hi everyone I was wondering what the best way to go here. I am Mitsubishi MD Pro 3 wiring 4 axis profile with a max 23 dg angle in a 2 inch thick piece of hardened steel. I am using the angle master flush cups and diamond guides. I am also using soft Mega T wire too. I am using the power master feature and I have the angle set properly in the interface.
Here's what's happening. The first rough cut goes great then I have it programmed to go back to the thread point where it dwells,changes the power,starts the wire and then goes to the machining cycle. About about 5 seconds into the program when the machine is imparting the first angle before the machine even makes contact the machine stops (please note the roller wheels jerks a little)! So I try a dry run out in the open off the piece to try to figure what the heck is happening then boom it duplicates the same thing. I feed hold the machine and sure enough the wire is broke down by the bottom flush cup. So I went to hard brass wire and ran the same program to make sure it wasn't the program and it ran no problem at all. Oh I forgot to mention I am using .010 wire.
Here's my questions:1) Is running the power master feature not recommended? Are there setting I am missing in this feature? 2)Should I run with Power master and if so any recomendations on settings?3)I know it has to be a wire tension problem or possible a wire speed problem?
Thanks!
Thanks!
