pin fixture for wire EDM
Hi 440CC:
I built one that does 10 pins at a time up to 3/4" diameter.
It's for cutting ejector pins (I hate the mess the smell and the racket of cutting them off on the surface grinder, especially the big ones).
I made mine with two blocks connected by two round rails so I can slide the front part of the fixture into the worktank to support long pins.
The front part is 10 Vees all in a row, and the back part is just a surface ground stop plate.
I clock the stop plate in on the X axis, slide the front Vees forward until they're a bit shorter than the shortest pin I want to cut, then lock the front Vees in place.
I wrote a program that allows me to set the return pin length as my reference length and input all the EJ pin lengths relative to the return pin dimension.
I also input all the pin diameters so I can rapid between pins.
I wrote it to do either one or two skims on each pin face after the cutoff.
To use it, I load up and cut one return pin about 0.100" too long and measure it, then reset my reference length, load up all my pins and push the green button.
I can walk away and let it burble along by itself.
It cuts the pins as accurately as I can make them on the surface grinder but it is quite a bit slower.
Biggest benefit though is that it's autonomous, and EDM wire is a lot cheaper than my time.
The fixture is very simple, just a couple of hardened Stavax bars and two big ejector pins for rails.
I made a dozen locking screws with knurled heads out of brass and turned a cone point on each so I can grab pins down to about 0.0313" diameter.
I wired the holes for the rails to be a nice sliding fit, and wired the Vees just big enough to accept 3/4" pins.
I made them teardrop shaped with a roof over each Vee so I could tap them for the locking screws.
All together I spent maybe a day making it.
Cheers
Marcus
Implant Mechanix – Design & Innovation - home
