sapwood
- Dec 7, 2013
- sunderland
Got a murex autolynx 160mk2 and it isn't welding right. at first thought it may be capacitors, of which it has two big 250000 oil filled electrolytics. well ive actually tested the caps tonight and with multimeter set to 2000 ohms the caps, both of them respond like I was advised they would if they were good caps. after discharging them from taking them out. with the meter probes on they slowly ramp up and keep going, if I switch the leads it does the same but ramps back down.
I have found out something from the seller of this Murex mig today that he had the machine looked at before giving me it (could have told me earlier) and the engineer told him its got problems controlling voltage CV and the wire feed motor isnt working right. But the motor sounds fine to me and pushes wire fine. ramps up its speed if I turn the dial and vice versa? Also didn't understqand how he stated it had problem controlling voltage. I have the rated and proper voltages measured at the tip from my meter. I thought it amps that the wire feed side controlled and this also being where a mig gets its heat/penetration from was the machines ability to control the amps relative to the arc length it monitors and the wire feed setting.
Some to summerise my two caps are fine and im now looking within the wire feed and also towards measuring the machines amperage delivery at the tip when welding....
CAN ANYONE ADVISE OR ADD TOT HIS WHO HAS MORE EXPERIENCE......
