I have a frame that was constructed with angle, 2"x2"x.25". The frame is 4'x3'. I want to add two 3' lateral supports made of 2.5"x2.5". Should these two supports bet notched, so they are flush with the existing frame, or should they go under the frame? I know there will be some material hanging over no mater which method I use because of the extra half inch.
It's going to need to be able to hold a lot of weight, around 300-600 lbs per end. It's holding a 1200 lb surface plate plus whatever is on top of the plate. I'm more interested in what will be strong, not really cosmetically appealing because I won't see it.
I'm also having a hard time finding out how much weight a weld is supposed to be able to hold. The material is made of 304 stainless, and I will do some test welds on some scrap material to see how they hold up when compressed.
