bending 6061 T4 ? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    May 2011
    CANADA
    Saskatchewan
    540
    346
    238
    5052 aluminum is indeed the best choice for bending+welding, also it takes a powdercoat better than anything else (will basically never chip or separate). I would highly recommend if you're set on going aluminum, to powdercoat it after (especially for intended application).
  2. #22
    Nov 2004
    Birmingham, AL
    12,999
    6060
    2400
    " This is the temperature at which wood starts to char, so just stroke a stick on it till it leaves brown traces."
    The tried and true method is blacking the surface with an acetylene torch using no oxygen, then add oxygen to a neutral flame and heat until most of the black vanishes. Cool in water or let air cool. Water is faster and lets you get back to work quicker.
  3. #23
    Nov 2007
    marysville ohio
    8,624
    2442
    5467
    Why are you welding a tube on, why don't you find someone with a set of curling dies for their pressbrake and form them all in one piece? In the late 70's early 80's I worked for Kawasaki building prototype snowmobiles. We bent the tunnels and running boards out of 1 piece of .062 5052. The running boards had a 3/4" dia curl on the edges with no welds.
