matt_isserstedt
- Dec 15, 2003
- suburbs of Ann Arbor, MI, USA
Have a part to make where I have a hub to attach to a shaft. Both parts are 1018 steel and I control all the dimensions.
Roughly, 1-1/2" dia shaft, hub is 1" wide.
I have considered welding but the undercut and fillet is undesirable and I may warp the shaft.
As I recall (if recollections are correct) solder does very well from a shear strength perspective when the joint is tightly fitted, and I believe I can get it into the .001" diametral clearance range.
What I am hoping for is a silver-based solder/flux combination that "wicks" like the old lead-based plumbing solders (really my only experience with solders other than electronic solders and standard brazing - which I know does not wick very well). The goal is if I can get to full penetration thru the 1" length it will likely be stronger than fillet-style welding and with less induced stress and no fillet to get in the way. Hopefully a paste-style flux too which I can apply easily to both parts.
Your sage advice is greatly appreciated, I am really a solder dummy you also might tell me I can't get there from here too...which I can accept...but thought I'd ask first.
