Thanks for the info guys, tried making another cut last night with better results. I should explain that I am trying to cut 6" disks out of 1" plate, I am after the disks and don't mind wasting a little bit of the plate. So, last night I cleaned the #2 tip, checked pressure settings, got better positioned, and started to cut. The first half circle cut just fine, then I repositioned and started the 2nd half, very quickly I started having the same old problem with bubbles, it looked molten metal was flowing back into the cut (even with the torch tilted forward), blowing into a large bubble and then popping with hot stuff flying everywhere. I finally gave up on the second cut, flipped the plate over and cut from the othe side (still with some bubbles). After things cooled down I looked at the cut both on the disk and the plate, what I saw was nice straight cut lines going all the way through on the first half, and a line that started straight and then curved back away from the direction of the cut on the second half. I compared the cuts with pictures in an old welding book and it said that the curved lines and mess at the bottom of the cut were caused by going to fast. I really thought I was cutting at the same rate for both halves of the circle, but, I guess not, the only difference I can think of is; on the first half I was able to rest my arms on the plate and cut from my right to my left, on the second half, the plate was to hot to steady rest and it was more of a freehand effort. So, what do you think, cutting speed and steady rest problems??
Thanks again, Glenn
