mattihorn
- Mar 19, 2006
- Southern Ontario
Hi can anyone give me a run down as to what settings on a tig welder (I have the miller dynasty 200dx) will allow to get good welds with low warpage?
I am using about 6 amps main, low background of about 10% of main. 75% on peak level. pulsing at 440hz.
I have been experimenting above 6 amps and below 6 amps, will little results under 6 amps. changin the background and peak current levels in lieu of the main current.
There must be some sort of combination of those plus the initial slope current which will get a good bead going at low heat for this sheet metal.
any suggestions from resident pro-tig welders?
thanks
Matt
thanks
Matt
