metalmagpie
Titanium
- May 22, 2006
- Seattle
I was fortunate to recently purchase a couple hundred feet of 2/0 and 3/0
welding lead at a very reasonable price (considering). However, it had
clearly seen hard use probably in a shipyard since in several places the
insulation was cut and the copper had arced through.
There are two scenarios here: one where only the insulation is cut, and one
where maybe 10% of the copper strands are also cut.
I got some black heatshrink tubing and put that over the insulation cuts, but
it looks wimpy.
I would like to cut out a couple of sections and replace them with some kind
of splice joint, hopefully not much larger in diameter than the cable itself.
Does such an item exist?
Grant Erwin
Kirkland, Washington
it looks wimpy.
Grant Erwin
