rcoope
Stainless
- Sep 25, 2010
- Vancouver Canada
I was just apprised of a lab problem where all of the shelves in four cell incubators, which look like large bar fridges, are warped. This turns out to be a problem for certain cell growth protocols where they have 150mm petri dishes which need to be dead level so the growth medium is same depth across the dish.
The shelves are about 18" x 18" and (in two incubator models) are 18 and 20ga stainless with three 3/8" up flanges on the sides and back and the front folded down. So the folded edges are straight. To promote air circulation the shelves are perforated, maybe 25% open, but only to up an inch or so from the edge, which obviously is much neater as the flanges are all solid and smooth. It all looks CNC punched as the perforation holes looked like they were cleaned up on the back side a bit. At any rate, the shelves all either twist diagonally or bow up in the middle. I know my cookie sheets do this when cooking pizza at high temperature, so it makes me think the perforations have expanded the central plane so they can't get flat. I've folded plenty of 18 and 20ga metal and even if a regular sheet is warped when you fold up the edges they tend to flatten out pretty well.
I'm thinking of trying to fold up a shelf out of pre-perforated sheet, trading nasty edges (which don't really matter) for flatness. I've worked with 16ga 60% open stainless in the past don't recall it being all that distorted, possibly because the larger open factor gives more ability for the metal to relax. Or perhaps it's annealed or perhaps I'm just dreaming. At any rate I have a piece and will try. I'd like to know if anyone has seen this warping though and otherwise has any thoughts about how to make a really flat shelf that's perforated.
