MuscleCarNut
- Jul 7, 2011
- Kansas, USA
A quick introduction:
I am a small machine shop owner that is looking to expand capabilities. Currently, I have the normal assortment of machining capabilities, such as manual milling and engine lathes, VMC's, CNC Lathe, Wire EDM, ect. A fairly well rounded shop, but nothing extraordinary.
Having this equipment in the shop, I didn't want to do much fabrication work. I maintain a fairly clean environment, and didn't want the fumes, grinding grit, ect in the shop around the machines.
I currently occupy 2/3 of a good size building, and now have the opportunity to occupy the other third at a reasonable cost. Real reasonable...about 3000 sq feet for $400 a month, fully insulated, heated well, ect. I told myself if it came available, it would be the perfect opportunity to expand into the fab/welding area, as it has a dividing wall to my shop area, ventilation, big overhead door and what not.
Competition in my area have both Machining and welding/fabrication, and I feel it is a hindrance on my business only offering the machining. SOOOO now is the time and place to venture.
Not wanting to go overboard buying equipment, tools, ect. I need to make some smart decisions. I know right off the bat I can't compete with the bigger shops doing large work. I want to start off on the right foot, get some small orders for average size work (not building ships here) and slowly invest in more equipment as the jobs warrant or profits say I can.
Cut to the chase. I need some guidance here on just starting out as far as what I need to just make a go at it. Obviously welders, benches, clamps, ect. But what would you list as say the "Top 10" purchases I should be looking at just starting out? Sizes too..say for a press brake, shear, ect. Whats minimal sizes you would get for run of the mill sheet metal work in a fabrication shop. Looking at used stuff of course. What I am kinda looking for is what I can do without, and what I would probably need when starting this up.
Hope you all can give me a little guidance, and look forward to your words of wisdom.
