slodat
- Jun 8, 2010
- Vancouver, WA
I started building this table March 2010. I built it to support a 3' x 4' top with 4" overhang on all sides. Since then I have been keeping an eye out for a piece of thick plate or possibly a machine table to use for a top. If the plate worked out, I planned to drill and tap a grid of 1/2-13 holes so I can use commonly available milling machine clamps for fixtures and such.
The base is built out of 2"x3"x.125 tubing, like so..
The bottom is similar, it will have an inset in the center of one long side so I can sit at the table and weld. This is the beginning of laying it out to see how things will look.
When I built this it was my second welding project ever. I'm completely self taught. I used two pieces of 1' x 2' x 1" steel on top of my toolbox to put this together.
The casters are bolted to 3/8" plates welded to the bottom of the base, kinda like so:
I bought a portaband mount from Troy at Swag Off Road. At some point I plan to mount up some 2" receiver hitch tool holders. This will have the appropriate mount..
I used the table in the above form for the past 2.5 years. A week ago I spied this at a local scrap yard:
Negotiated a very good price for the table and it was mine. It had years of dried oil and chips protecting it from the elements. I scraped it off and power washed it prior to putting it in the shop.
Here it is after a couple of hours cleaning out holes and working on the surface.
I'll get the other half cleaned up and the surface looking nice in the morning. Then, I need to do some finish welding on the base and prep it for some paint. I am really excited to finally have found a top for the table I started so long ago.
The top piece is 21" x 49" x 1-7/8". Every other hole is tapped 1/2-13.
Was in the shop late last night and tonight. I had some finish welding to take care of. I added 2"x2"x1/8" angle stringers between uprights on the left side and rear. Grinders hang really nicely from the angle.
Then I laid out mounting holes on some thicker 1/4" angle to screw the top down. Welded this across the front.
At that point I set the top in place.
It took a few hours to get the top cleaned up and all of the holes cleaned out. It made a huge mess, but they are clean now. I used my RO sander to lightly sand the top with WD-40 as a lubricant. It worked well. Used 100 then 150 then 220 grit. Very happy with the how it is turning out.
I've been undecided about the area under the table since I started building it. I'm considering building a drawer cabinet to fit under the table. I have a bunch of full extension ball bearing slides and 3/4" plywood. Would be really cool to make the drawers match the shape of the cutout in the base. As I type this, I am liking that idea more and more..
I'm holding off painting the base until after I've used it for a while and the rear section (where the 1" plate is currently sitting) is sorted out.
