Pattnmaker
Stainless
- Nov 2, 2007
- Hamilton, Ontario
I bought a used Euromac PB350 bender a couple of weeks ago. I bought a manual from my local dealer for $100. The PDF of a photocopied manual is pathetic. I am going to have words with the dealer when they are back in the new year. The manual has numbers that relate to "picture 1" but there is no picture 1, the manual tells me certain leds should light up on the card when I press the two buttons to make the ram advance. The numbers of the leds don't correspond to the colours the manual says they are. When I first started the bender there was no movement and no pressure on the guage which makes sense seeing as the valve is an open center valve. I noticed a loose plug on the card, now it has pressure but still will not move so I assume the cylinder is in retract mode.
Does anyone have picture one or can you tell me what all the buttons do? I can sort or guess at some of them but it would be nice to know for sure. Is the knob on the right side of the machine a pressure adjustment or speed? Does anyone have a drawing for the card, the schematic I have just shows the wires entering the card. Any suggestions for making it work?
